Out Side Camper Lights
Does anyone know where the fuse is for the outside camping lights. These are the lights that are turned on just inside the double doors, and the lights themselves are on the right and left rear of the camper...for a 1993 B190.
Open the fuse panel (under the couch). If it's wired like mine, you'll find only three or four fuses in there, and all of the lighting and the fans are wired to the exact same circuit. But open that door and take a look - it is possible to wire in extra circuits and that could be the problem.
Or the switch went bad or a wire came loose somewhere. If it's not the fuse, I'd get to the back of the switch and check for a constant +12 volts on one side of it, and switched +12 volts on the other.
