B190 database
Re: B190 database
download/file.php?mode=view&id=1602
I just purchased my 1990 B190 in August of 2022 in Hot Springs , AR. Here is a photo of the info on it.
- Attachments
- D83C3C02-00AC-468B-BA85-A3BE4E2C9188.jpeg (1.11 MiB) Viewed 34245 times
Re: B190 database
Yours is kind of interesting - it's a 1990 chassis, but a 1991 Airstream VIN. In other words, when they built yours in the 1991 Airstream model year, the chassis was a leftover from 1990. So for any slight differences between those years, you're more likely to have the 1991 design. Of course, they didn't always change designs right at the beginning of the model year, so anything is possible.olBronco wrote: ↑Tue Sep 20, 2022 8:08 amdownload/file.php?mode=view&id=1602
Also, yours is the lowest numbered 1991 we've seen so far. Innnnteresting!
Re: B190 database
1991 Airstream B190 Airstream VIN#1FDHS34G7LHB84165
VT didn't register the FORD VIN
- Attachments
- b190.jpg (205.46 KiB) Viewed 33961 times
Re: B190 database
Got it. Also, you might find this interesting. It also appeared in this very thread!Junkyard_sal wrote: ↑Wed Mar 01, 2023 2:46 pm1991 Airstream B190 Airstream VIN#1FDHS34G7LHB84165
Re: B190 database
My van is passing through a few b190.com hands. I guess this makes me owner number four with an average ownership time of 8 years.
Re: B190 database
Hey @skater, I feel like I've seen this somewhere on this forum, but what's the latest airstream VIN number you have in your database? Mine is 1378 and I'm just a little curious roughly how many were made after mine.
1999 B-190. Owner since 2021
Re: B190 database
We know the sequence numbers go up to 1,393, because a B190 owner who sells Airstreams knew their dealer got the first Airstream B van that wasn't a B190, and it had 1,394 as its sequence number. So yours is definitely one of the last of the line!taitecklund wrote: ↑Mon Jul 24, 2023 2:18 pmHey @skater, I feel like I've seen this somewhere on this forum, but what's the latest airstream VIN number you have in your database? Mine is 1378 and I'm just a little curious roughly how many were made after mine.
But...the highest B190 VIN I have in the db is #1379. It's a 2000 model year.
This is actually really good news for the database, though. And it's raising one issue I have with the database that I'm not sure what to do about. I currently run it by chassis VIN, because I have those much more often than I do the Airstream VINs. The counts of "number built by year" posted elsewhere are almost certainly by Airstream year. As we've noted, the chassis year doesn't always line up with the Airstream year - SheilaG's is in fact a 1999 chassis. (I'll note these were both in the database already, but because of the organization issue, I didn't spot it.)
So, right here we have a perfect example - your 1999 is the very last 1999, and the very next number (Sheila's) is a 2000. But the database isn't recognizing that connection because it's working by chassis year, not Airstream year.
What's the good news, then? Since we now have one of the changeovers pinned (#1378 was the last of the '99s, and #1379 was the first of the 2000s), and we know how many Airstream made most years, we can theoretically figure out the lowest and highest sequence numbers for each year.
Re: B190 database
Wow. That is really cool to have this data and know it. I did run into someone online recently who mentioned they had a 2000, which was news to me that there were some with 2000 Airstream years associated with them. I wish I remembered who it was so I could go back to them and try and get them to give you their VIN to add to the database.
Re: B190 database
Using the logic in this post, I did this. Note this is a theoretical year/sequence number table, it's not confirmed (and I haven't even checked it against the database for the Airstream VINs that I do have).
Edit: Never mind, this isn't correct...several Airstream VINs are out of the range of the values given here. Hmmmmmmmm.
Edit 2: This is weird, but here's the issue...
1B9KGVA28XJ301368 - 1999 - #1368
1B9KGVA20XJ301378 - 1999 - #1378
1B9KGVA25YJ301376 - 2000 - #1376
1B9KGVA20YJ301379 - 2000 - #1379
If you look at the sequence numbers, they made a 1999 model AFTER a 2000 model.
Bummer...thought I had something there. Sigh.
- New User
- B190 Year: 1995
Re: B190 database
Hi, I’m new to this, but was asked to register my fast moving house here.
1995 b190 vin#1fdjs34g2sha33783
I’m not sure where to find the airstream vin. I’d love to contribute in anyway I can. Thank you
Re: B190 database
Welcome to the site! The Airstream VIN is usually embossed on an aluminum plate under the hood (usually just above the radiator).Todd Sargent wrote: ↑Mon Aug 28, 2023 9:15 amHi, I’m new to this, but was asked to register my fast moving house here.
Also - where are you located? Roughly - we don't need your exact address or anything like that.
Thanks.
