Re: Fuse on back of control board?
Posted: Wed Aug 24, 2016 10:24 pm
While its out, change the oil. Hard to do in situ unless you have a special drain set up.
Glad you found the problem.
Website for owners of Airstream's B190 and Okanagan campers: "It's not a slow car; it's a fast house!"
https://www.b190.com/
Good advice. And consider modifying the generator compartment in the camper to allow the oil to be changed without removing the generator from the camper.Planck wrote:While its out, change the oil. Hard to do in situ unless you have a special drain set up.
