Page 2 of 4
Posted: Fri Feb 12, 2010 10:05 pm
by Alaskan
Yes Clint....I made up two more sets.
Kits made up and sent out to Dale & Eli....
Posted: Tue Sep 07, 2010 12:11 pm
by Alaskan
I recently mailed a spacer kit down to Jeff in California...
At the time he installed the spacer kit he also replaced his front springs with new Ford springs for a E350/F350 diesel
He tells me it raised the front of his rig about 3 inches...
rear suspension
Posted: Tue Apr 12, 2011 11:17 am
by JimL
Hi all!
I too had some problems with my rear springs sagging and a scraping of the braces on the back added by the previous owner. I took the unit (with about 95,000 miles) to a prominent spring shop in the area thinking they were going to clean me out to replace them. I was very happy with them recurving the old leafs and adding another to add support. They are now basically E-450 springs and add a lot of rigidity to the coach for going around corners or even just going down the road. It seems as though crosswinds are not nearly as noticeable as before, and I forget that I am pulling when I have a trailer in tow. I can't comment on the validity of other fixes mentioned here, but I can say that I could not be more pleased with the solution I have found.
Posted: Tue Apr 12, 2011 2:04 pm
by Alaskan
Jim.....thanks-a-lot for the input.
A problem with re-arching the springs and adding a leaf is it significantly affects the spring rate and therefore makes the ride more rough than it was originally.
With 2-inch riser blocks there is no affect to the spring rate.....
We've had a number of members add an aftermarket rear sway bar to address the other issue you mentioned.
spring rate
Posted: Wed Apr 13, 2011 3:38 pm
by JimL
Agreed. The spring rate is much stiffer and Many members may not appreciate it being closer to a performance machine than a recreational vehicle. However, if you plan on doing a lot of pulling, I think it is a very viable option.
Posted: Wed Apr 13, 2011 3:46 pm
by Alaskan
Jim.....
video clip from yesterday, 2-inch riser kit.
CLICK on the picture... ! VIDEO CLIP....
Re: Rear Suspension Modifications
Posted: Sun Dec 13, 2015 8:36 pm
by Alaskan
I have 2 kits left.....
Posted: Mon Dec 14, 2015 11:38 am
by Tucsonan
Hi Dave, what are you asking for a kit?
Posted: Mon Jan 18, 2016 7:23 pm
by Alaskan
One kit going out to Atkins Family tomorrow.....
Kit...
1-set 2-inch riser blocks with locator pins (tig welded in place)
4- Custom made u-bolts with heat treated hardened thick washers and tall nuts....
1- USPS Large Flat Rate mailing...($18.75)
$220.00....includes the mailing
Posted: Wed Jan 20, 2016 6:23 pm
by Alaskan
Another kit....out to Adkins Family...
Does require the Large Flat Rate USPS box.....@ $18.75
Posted: Fri Jan 22, 2016 12:41 pm
by Adkins family
Adkins family here, we would like to thank you for your time and effort Dave. If you have a picture of the riser installation (mounting location) I would like to see it please.
Cheers!
Posted: Thu Mar 24, 2016 6:34 pm
by stomper18
Hello Dave.
I'm the proud owner of the 1999 that was recently posted for sale right here on this site.
I can see I will need to raise the rear end to prevent scraping and make the vehicle more functional here in Colorado.
Could you put together a kit for me?
Alan Jacobs
Posted: Thu Mar 24, 2016 9:12 pm
by Alaskan
Sure will........gimmie a about 3 weeks or so as we are just heading out tomorrow to the Tesla factory in California...then the Winsor Colorado
and up the Calgary for a week...(Spring Break)
Posted: Thu Apr 07, 2016 2:04 am
by stomper18
Alaskan wrote:Sure will........gimmie a about 3 weeks or so as we are just heading out tomorrow to the Tesla factory in California...then the Winsor Colorado
Dave are the Hellwig anti sway bars compatible with your lift blocks? I'm thinking I'll install everything at the same time. Let me know when you're home from your Spring break adventure.
Alan
Posted: Sun May 15, 2016 7:03 pm
by Alaskan
