Page 2 of 2
Posted: Thu Mar 31, 2011 5:38 pm
by Planck
Well, since I started this post, I will ask a question:
How many of you drive and have the fridge in gas mode? That is what the manufacturer recommended when I called them with fridge questions. I suppose thats okay with a trailer, but with gasolene fumes, I would think that if it is in gas mode, it should be shut off during re-fueling.
Posted: Thu Mar 31, 2011 11:13 pm
by bobbyv
Planck, normally on 120v it takes about 8-10 hours b4 a trip to get our fridge really cold. If it's in the winter it only takes about 2hrs. I load it up and just b4 we leave I switch it over to 12v, that way when I'm pulling into a gas station I don't have to mess with turning the propane off. I find that if you don't open the fridge too often it will hold the cold just about all day on 12v. By the way, it even keeps our icecream frozen. Then by evening I will switch to 120v if I have hookups, or propane if I'm dry camping. So far this works pretty well for us.
Posted: Fri Apr 01, 2011 7:31 am
bobbyv wrote:hey I just thought about it, I'll leave it up to you brainiacs to figure it out.
We'll get right on it.
Refrigerator info
Posted: Fri Apr 01, 2011 5:19 pm
by craigmar
In reading all the posts, I thought I'd refer folks to a June 2009 post in the appliances forum that I made. I've been running with the fridge for a couple of years now and have never had a problem with keeping things cold and frozen even in the middle of the desert during the summer. I am however, thinking of buying a small ice maker to supplement the cooler ice and maybe makeing a few dollars selling ice to those folks that run out of ice in the middle of their trip and the nearest 7-11 is nowhere to be seen.
Re: 1991 12 volt fridge info
Posted: Sat Aug 06, 2011 9:59 pm
by OnTheRoad
Planck wrote:I traced the problem to under the bed where the circuit panel is. There was a relay there that had been altered that was tied in to the 12 volt fridge.
Ahh, this looks like the answer to my question in this other post about the fridge wiring:
http://www.b190.com/modules.php?name=Fo ... opic&t=769
I'll see if I can find this relay under my couch.
