Just got a quote for $250 to change the oil and replace the air filter on my Onan generator. That has 175 hours on it (but spent a lot time in dusty deserts) He included 3 hours of labor for the job @60hr
Does that seem right?!?!
Generator maintenance
Travelisaverb
- B190 Year: 1995
Re: Generator maintenance
Seems high, but keep in mind there’s labor to remove it from the camper if the drain isn’t accessible, and to reinstall it.
It weighs 120 lbs or something so be ready if you choose to do it yourself...and while you have it out, install access for the oil drain.
slapthecat
On mine (a Revision A gennie) the drain plug is to the right, and the power hookup is on the left. I've got enough play in my lines that I can remove the side brackets and swing the gennie out enough to get to the drain plug (I use a couple of milk crates to support the end of the gennie hanging out of the rig). It's not the cleanest (or smartest) way to do it, but it works and I don't have to take everything apart! (I can't add access to the oil plug because it's directly above my propane tank)
Not related to maintenance, but wondering which gas tank the generator line is tied into. Just purchased a 1991 B190 and trying to learn as much as possible about my B190.
Cowboy
Cowboy
The front tank in mine. If you crawl under, it's tee-d off just before the fuel selector.Cowboy wrote: Fri Sep 18, 2020 2:00 pm Not related to maintenance, but wondering which gas tank the generator line is tied into. Just purchased a 1991 B190 and trying to learn as much as possible about my B190.
Cowboy
