Propane tank removal
Re: Propane tank removal
Last photos...still need to fill it and verify everything works, but that's for later!
- 06 tank painted.jpeg (3.23 MiB) Viewed 32945 times
- 07 front bracket install detail.jpeg (2.58 MiB) Viewed 32945 times
- 08 installed tank.jpeg (1.76 MiB) Viewed 32945 times
- 09 new tank monitor wire fittings.jpeg (1.64 MiB) Viewed 32945 times
Looks great! I should do that to mine, which isn't nearly as bad as yours was.
- Oldbagpipe
- B190 Year: 1989
Nicely done! This is on my 'list', but still a ways down. I'll be back to this thread when ready. Thank you
Very nice!
A bit anal repainting a tank no one will see because of a few scratches, though, no?
Branden - sorry for the very late reply, but I only just saw your question. It's probably a moot point by now, but the work was done at Allied Propane in Richmond, CA.silvertrooper wrote: ↑Thu Mar 24, 2022 6:41 pmHey Rugster,
Who did you have do the work? I've got a similar problem with a leaking shut-off valve, and LP places say they won't work on the chassis-mounted tank, and RV places say they don't do LP, or it's too old (1996) for their shop.
I'm now just thinking about doing the work myself--looks fairly easy since the tank is empty. Problem is, I don't know what valve to use. I suppose I cold just remove it then see if I can match it...
Thanks for any tips!
Branden and the Tourtle
What is the name and size of the fitting to the right of the fill valve in the bottom picture ? I just found out that fitting must be stuck open as I have a small leak even when tank not over filled. I suspect the last person who filled it didn’t know how and he overfilled it. I need to replace it but don’t know exact name and model of the part. Any help greatly appreciated????
Barbara
Barbara
Does anybody’s know if this will fit my original propane tank on my 1998 B 190?
Emerson Fisher 3/4 in. MNPT External Relief Valves for ASME Containers - 250 PSIG
I’d so I can get it in time for my trip. If not sadly won’t be able to use refrig or stove.
Thank you
Barbara
Thank you
Barbara
This is the pressure relief valve off my 1998 tank. Does anybody know where I can order a replacement???
Thank you
Barbara
Thank you
Barbara
- Pressure relief valve
- imagejpeg_0.jpeg (154.4 KiB) Viewed 32090 times
- imagejpeg_0.jpeg (161.49 KiB) Viewed 32090 times
- imagejpeg_0.jpeg (145.05 KiB) Viewed 32090 times
- imagejpeg_0.jpeg (226.96 KiB) Viewed 32090 times
