Airstream B190 brochures and manuals
History of the B190, along with flyers and option sheets from several years. (Added 3/7/13 - Updated 5/31/2020 with some corrections by Millennial Falcon)
1991 B190 brochure: front back
1991 B190 owners' manual (this is a scan and OCR of mine, but a few pages on the warranty and maintenance schedule are missing)
1992-1995 B190 brochure: front back
1996 B190 brochure: front and back (pdf)
1997 B190 brochure: front and back (pdf)
1998 B190 owner's manual (Word format)
1999 B190 specifications and features
Airstream has put a lot of manuals and brochures online.
Other manuals:
Dometic refrigerator owner's manual
Parts diagram for the Horizon box awning. The second drawing is the awning my 1991 has. (Note many of these parts are no longer available, unfortunately.)
Generator service manual
Other manuals:
Re: Airstream B190 brochures and manuals
Hi, folks! I just added a PDF with the history of the B190 and flyers from several years. See the first link in the message above!
The history pdf is an interesting read. Really interesting to see the evolution through the different models. Thank you for posting!
- Millennial Falcon
All of these links say FORBIDDEN ACCESS when I try them, are they hosted somewhere publicly, or are they lost after a previous webhost switch?
Nope, I have them. I had them in a directory that was set up to disallow access. I've corrected the issue now! Thanks for pointing it out.Millennial Falcon wrote: Mon Oct 01, 2018 2:36 pm All of these links say FORBIDDEN ACCESS when I try them, are they hosted somewhere publicly, or are they lost after a previous webhost switch?
- Millennial Falcon
Skater,
I was searching for things online and found a few better copies, colorized versions, and missing pages from the Brochures you have saved as a .pdf at: http://b190.com/manuals/B190_History_and_Flyers.pdf
I also rotated it so all files read in the correct "up" orientation... and specifically fixed the 1997 page so the photo and the text are both the same alignment.
If you'd like, please feel free to host it with your other documents, and update your link above? I will put it in my DropBox at the link below, but please host it here on the site as I'm not sure how long I can keep my DropBox link alive.
Here's the new version: B190 History and Flyers (corrected)
Thanks!
Sarterfish
Has anyone here put together a "checklist" for driving, parking, and camping? Sort of an "Operation manual for the B190 Dummy"? My son wants to borrow the van for camping, and something like this would be extremley helpful for letting family and friends use my new van.
I started putting one together, but figured someone has probably already done this and refined it.
Why "reinvent the wheel"?
I had a packing list, but nothing beyond that.Sarterfish wrote: Thu Jun 08, 2023 9:40 pm Has anyone here put together a "checklist" for driving, parking, and camping? Sort of an "Operation manual for the B190 Dummy"? My son wants to borrow the van for camping, and something like this would be extremley helpful for letting family and friends use my new van.
I started putting one together, but figured someone has probably already done this and refined it.Why "reinvent the wheel"?
Sarterfish
I'm working on a basic operations manual for driving, parking, and camping, so I can lend her out with an easier mind and confidence that people will know how to treat her right.
. I will share with the group once the 1st draft is finished, and ask for advice on editing.
First question that I do not find in the fridge manual; What are the best fridge settings for;
A. Driving ( I assume 120v as the engine will power?)
B. Parking for a few hours (maybe 12v as the battery can handle that without too much discharge?)
c. Longer term camping (Propane vs. 12v, any advice?)
Sarterfish
Ok all, I've finished the "first draft" of my personal B190 user manual. Here's the link, let me know if you have any suggested edits or additions!
https://docs.google.com/document/d/1NJv ... sp=sharing
- Sarterfish
- Sarterfish
While you're driving, there is no 120 volt power, unless you're running the generator or an inverter.Sarterfish wrote:I'm working on a basic operations manual for driving, parking, and camping, so I can lend her out with an easier mind and confidence that people will know how to treat her right.. I will share with the group once the 1st draft is finished, and ask for advice on editing.
The 12 volt mode is only active while the engine is running. It would suck down your battery power quickly otherwise. (Assuming stock wiring.) But the 12 volt mode is pretty weak - even the owners manual basically says it's not very good.
For long term camping, 120 volt if you have shore power, propane otherwise.
On the road, if I had the generator on, I'd use the 120 volt mode. If not, propane, but the few times I tried it, the flame went out (it shouldn't, but I never got around to diagnosing it).
Sarterfish
Thanks a million Skater! Maybe my fridge will work after all! I will try the propane, but that'll only work when it's level right? How level does it need to be? So, what I'm reading from you is;
Driving; 12V for minimal cooling, or generator for 120V if I really need it "cold"
Parked; Whie boondocking, propane only as the 12V will kill the batteries. Shore power if it's available in a powered site. (I have 2 house batteries in my rig, one under the hood and an AGM installed by a previous owner.)
Thanks!
-John
Thanks!
-John
