brooklynbus wrote: Sun Aug 03, 2025 4:52 pm
Hi Skater,
I'm now on my second b190. My current, which I've had about 3 years is a June 1999 build with Airstream production number 301389. The plaque I took the image from only shows these last 6 digits. I'll try to find another plate.
Seems like their numbers were all over the place by the end of its run.
Not sure if you need the Ford Vin.
I actually track them by the Ford VIN because, if any ads include a VIN, that's almost certainly the one that it'll have.
Yours would be the new highest VIN we have - definitely interested in both VINs for yours.
#301389 should be a 2000 B190 (the chassis might be 1999, though). If so, the Airstream VIN would be: 1B9KGVA24YJ301384
Skater I was looking at your? Spreadsheet and mine doesn't fit the criteria either
1992 with #472
I just registered #GillyB190Van
on the database here too
thatChrisLady wrote: Tue Oct 14, 2025 1:09 pm
1992 with #472
I'm not sure what you mean - #472 fits right in the known sequence numbers for 1992 models (for 1992 models, #345 is the lowest I have, and #481 is the highest I have).
Thanks for supplying the VIN info! I've added them to the database. It wasn't in the database before.
