For Sale: 1995 Airstream B190 Camper Van – 82,000 Miles –SUPER CLEAN READY FOR ADVENTURE!
Looking for a classic van with modern upgrades and road-ready reliability? This 1995 Airstream B190 blends vintage charm with thoughtful improvements, making it a perfect choice for weekend warriors, full-time vanlifers, or collectors of iconic rigs.
This B190 has received extensive care and upgrades, primarily from the previous owner, with most work documented via receipts. Highlights include:
Mechanical & Drivetrain
Belt tensioner pulley & serpentine belt replaced (2017)
Cruise control release switch replaced
Differential pinion seal replaced ($536.78)
Rear sway bar installed & steering box adjusted ($250.03)
New tires: Savero HT2/GT Radial ($613.20)
American Racing wheels ($800.00)
Exhaust manifold gasket replaced, broken bolt removed ($870.04)
New (used) instrument cluster installed; gauges repaired
Coolant temp sender & oil pressure sender replaced
Alternator tensioner tightened (2022)
Interior & Comfort
Van seats and bench reupholstered in grey ($900.00)
Front door panels repainted
Light behind heater control replaced; gauges checked
A/C heater control switch replaced
Maxxair MaxxFann with remote & rain sensor installed ($452.96)
New auxiliary battery (2022) ($444.31)
Plumbing & Appliances
Rear plumbing replaced with PEX (2017)
Refrigerator serviced: gas/pressure test, thermocouple & gas valve replaced ($231.45)
LP system overhaul: regulator, pigtail, selector switch, extender replaced ($239.09)
New water pump and showerhead installed (2025) ($90.00)
Toilet removed, new floor installed, drain capped (2022) ($400.00)
Replacement city water connector included but not installed ($60.00)
Cummins Onan generator serviced (100 hours): new muffler, spark plug, head studs, gasket, fuel line, oil & air filter, bench tested ($1,346.53)
Retractable power cord removed; new 30A cord and exterior plug installed ($150.00)
🖌 Exterior
Running boards removed and repainted ($219.00)
Headlights and Running lights replaced. ($50.00)
Total Documented Upgrade Investment: $7,652.69
(Excludes labor for some upgrades and general maintenance like oil changes, which are also documented.)
Additional Notes
82,000 original miles
Clean title
Majority of receipts available
Original toilet not included, but tanks and plumbing remain intact
City water connection leaks slightly; replacement part included
This B190 is a rare find—mechanically sound, tastefully updated, and ready for your next adventure. Whether you're chasing sunsets or restoring it to showroom glory, this van is a solid investment in freedom and fun.
Serious inquiries only. Let me know if you'd like to schedule a viewing or request more photos. If the listing is up, then it is still available.
Here is a link to Marketplace;
https://www.facebook.com/marketplace/it ... tn__=-UK-R[/url]
Link to an 11 minute video of the systems and general tour of the vehicle;
https://youtu.be/kTeauBakF6w?si=e2AesakYvRd7Wbcf
