Starting Problems
- craigmar
Starting Problems
Here's another tip that might help someone else...
Mine would occasionally be slow to start turning over, but would always fire up immediately once the starter started running. Well, today, it wouldn't start at all (while it was blocking my driveway, naturally). When I'd turn the key, the starter wouldn't run at all. Battery seemed strong and jumping it didn't help. Starter hasn't ever given me any issues either. The battery terminals seemed tight, and though there's some corrosion it's not a lot.
The answer turned out to be a wire on the relay was loose. This wire can't be more than 16 gauge or so, and it has a rubber boot on the end that slides over a terminal on the relay, but the rubber is apparently worn out and now it doesn't hold it securely. I pushed that back on and tried to start it, and it fired right up! The wire in question is red. The relay is mounted in front of the engine battery; you kind of have to lean over the battery to see it. Follow the positive wire from the battery and you should find it quickly.
It must be some kind of voltage sensing wire or something, because I don't think it's even heavy enough to be the ignition wire. It's certainly not one of the battery cables or anything like that.
I think they switched to EFI for the '89 model year or perhaps even a bit earlier, but I'm not sure.Alaskan wrote:What year did they stop using a carb I wonder.. ?
His 1989 may not have EFI...
P.S. The solenoid is what I meant when I was talking about the relay.
