Power seat, no power.
Choptop
Post by Choptop »
Just pulled the B out, after a long winter in the enclosure. Power seats worked when I put it away, did not work the first time I hit the switch, then did work now neither works again, were is the fuse/power for them Thanks
Re: Power seat, no power.
Choptop wrote:Just pulled the B out, after a long winter in the enclosure. Power seats worked when I put it away, did not work the first time I hit the switch, then did work now neither works again, were is the fuse/power for them Thanks
In mine, there is a bundle of wires under the floor mat. I’m pretty sure there’s no specific fuse for the seats.
Choptop
Post by Choptop »
Thanks Skater, will just start checking wires and fuses.
On my '93, the seat power comes from the coach battery not the engine battery. If your B has been sitting for the winter, you might want to confirm that your coach battery has a full charge.
Choptop
Post by Choptop »
Thanks Kentuckian, makes sense, but it worked momentarily w/out the coach battery in . :(
Choptop wrote:Thanks Kentuckian, makes sense, but it worked momentarily w/out the coach battery in . :(
Was it plugged in at that time? Also, check the fuses in your fuse panel.
Choptop
Post by Choptop »
No, so I think in my case it may not be the battery, more a bad connection from sitting, but I am charging the coach battery and will put it back in to check.
Choptop
Post by Choptop »
Well I had put the coach battery, it's old and kinda weak, on the charger this morning. Just put it back in the B and WaLa, the seats work, but why did they work a couple of times with no coach battery in ? It must B possessed ! lol
Choptop wrote:Well I had put the coach battery, it's old and kinda weak, on the charger this morning. Just put it back in the B and WaLa, the seats work, but why did they work a couple of times with no coach battery in ? It must B possessed ! lol
Was the engine running or ignition on? When it is, the relay will power the coach system.
