SOLD - 1992 Airstream B190 Camper Van - { I was going to delete the post after it sold, but can't seem to figure out how. }
I am the third owner. I purchased this from my grandparents and have been slowly restoring it over the last few years. It still needs a number of cosmetic details and upgrades but everything is in good working condition. I have only used it a handful of times and feel that rather than letting it sit in my driveway it should go to someone that will be able to utilize it more than I have.
This airstream was originally purchased with many of the factory upgrades such as the larger 460 engine. It was stored for about 11 years in my grandparent's garage that they built for it. I purchased it in 2016 and have driven it out about 10-15 times. My partner has started it every two or three weeks and driven it around the neighborhood to make sure it is still running as expected.
Condition:
Used / Fair-Good
*Needs new tires*
*Needs slider accordion divider in front of bathroom needs replacing*
*the stick down faux wood plastic flooring that we put down doesn't seem to be the right fix*
*Needs bedding for loft area *
VIN: 1FDJS34G7NHA32746
Year:
1992
Make:
Airstream
Model:
Airstream B 190 conversion van
Class:
Class B
Austin, Tx {North East Pflugerville border as estimated by map}
Mileage:
72,000
Generator:
Onan MicroLite 2.8 Genset
Virtually new with only 48 hours on it. {Pictured}
Fuel Type:
GAS
Engine Type:
V-8
Sleeping Capacity:
4 {upper bunk measures 69" x 72" when expanded}
Length:
19'
Engine Manufacturer:
Ford
Noteworthy Features that not all of these campers from this decade have:
+ Towing Package
+ Awning in Great condition
+ working microwave, refrigerator, toaster oven, stove + oven
+ not noteworthy especially but a few have asked...so, yes, we have the seat belts for the bench seat
upgrades and repairs:
+ my grandfather updated the fridge to a 110 mini fridge with a 1200w inverter in the exterior access hatch
+ original carpeting was removed and replaced with vinyl faux wood flooring
+ carpet in drivers area has been replaced with new carpet
+ repaired HVAC controller / AC works great now
+ recharged AC system
+ replaced wood in bunk area
+ cut out bad wood in floor and replaced
Re: 1992 Airstream B190 Camper Van - $8000
If you guys see any glaring things that I should add to the listing, please let me know.
