For sale is my 1995 Ford E250 Coachmen. With only 59k it features a completely rebuilt interior, new Bilstein suspension, upgraded wheels and tires, and much more. The Engine is very clean and runs normally and the van drives straight on the highway.
The original Coachmen interior was removed and rebuilt using a combination of 3/4" laminated material and ½” bamboo plywood materials. The new layout features a “pass-through” floor plan and additional storage areas. During reconstruction all windows were resealed, any and all holes were plugged and resealed and additional insulation was installed. The upper bunk is original and better suited for soft good storage but could be a fun sleeping area for kids and measures 70" x 55". There is no supplied mattress for the upper bunk. The original sofa folds out into a bed measuring 75" x 44". There is a space on the rear driver side intended for a cassette toilet of your choosing.
The electrical system is quite simple and has room for upgrading as well. Currently there is a 100ah AGM battery charged by either the stock alternator (this van came from the factory with an AUX battery ignition switch solenoid), the solar panels, or by shore power via the Magnetek converter. There is a Victron 602 battery monitor, 12v fuse panel, and 120v breaker panel. There are power ports in 3 locations and feature usb charging and 120v power with shore power on the lower outlet and inverter power on the upper outlet.
The rooftop Coleman A/C unit only works on shore power and works very well!
The body is in fairly good shape though it does feature some damage. The Coachmen fiberglass fender flares and side skirts are solid but do have some noticeable cracks and chips in the paint. The body shows some damage to the front driver fender, driver door, and has 3 small screw holes directly behind the drivers door (have been siliconed temporarily). The drivers door is not original and the decal matching is a little off.
This van comes with a variety of extra materials for you to continue the customization including some laminate, bamboo panels, L-track, hooks and hangers, small rolls of fabric, camping stuff, some extra engine parts, and new wheel center caps. All records and receipts are included.
I'm happy to answer any questions over the phone and can assist in transport, shipping, pickup at the airport etc. I am selling because my family and I are moving back East and I may be able to deliver to anywhere in Oregon, California, the Southwest, and the Deep South!
$34000
If interested please CALL 484twofivesix8935.
For more pictures, videos, and a detailed build description check out my google drive:
https://drive.google.com/drive/folders/ ... sp=sharing
1995 Ford E250
59,000 miles
5.8 Windsor engine
VIN: 1FDHS24H1SHC02662
Clean OR title in my name
Electrical:
Renogy 20A MPPT solar charge controller
Xantrex 1000w Prowatt inverter
Alternator charging using the stock AUX battery solenoid
Magnetek DC charger/converter w/ upgraded internals and 12v fuse board
Renogy 100w solar panel
Victron BMV-602 battery monitor
Original systems monitor for fresh/gray/propane tank level sensors
Original 30a twist lock shore power plug
Heating/Plumbing:
Gasoline Webasto heater
Shurflo water pump
Original Atwood propane hot water heater
Original undermount propane tank
Propane detector wired in
Original fresh water tank - gravity fill only
Original gray water tank modified
Hepvo waterless drain valve
Updated sink and pull out faucet
Scandvik rear shower sprayer
Interior:
New ignition tumbler, door locks, and 2 keys
Original 3-way Dometic refrigerator
Ceiling lights on dimmer 3200k
Alpine headunit
Original passenger swivel seat
Original propane cooktop
Scirocco fan
3 reading lights
Flip up table at side barn doors
Flooring/Walls/Insulation:
Insulated window covers
½” closed cell foam insulation in the floor
Original spray foam / thinsulate insulation in the van body walls
½ closed cell foam / thinsulate in the walls and ceiling of the fiberglass
Lonseal coin grip flooring with ⅜” marine grade plywood subfloor
Ceiling and wall panels are upholstered with ⅛” closed cell foam
Sound deadening applied in various locations
Side and rear barn doors sound deadened and insulated with thinsulate
Suspension/Steering (all new):
American Racing 16x7 wheels
BF Goodrich KO2 245/75/16 tires
Bilstein struts - 33-187570 fronts & 33-176840 rears
Moog steering bars and tie rods
Moog control arm bushings
Moog upper and lower ball joints
Recent alignment
Engine (all new):
Starter battery
Fuel filter
Spark plugs and wires
Oil and oil filter
Serpentine belt, tensioner, and idler pulley
Exterior:
Rough Country 2” LED pods on the hood switched at dash
Truck Lite LED headlights
Coleman Mach 3 roof top A/C unit
New porch light
New lower refrigerator vent cover
Maxxfan 6200k
Updated front and rear bumpers sprayed with bed liner
Updated front grill and bumper
New insulated side compartment hatch door and frame
New seals on all Hehr sliding windows
Ceiling coated in a Ziollo silicone waterproofing / heat diffusing sealant
The fiberglass top screw strip was removed, cleaned, updated SS hardware, new black screw strip cover, foam seal and siliconed
Issues:
Some damage to front driver fender, driver door, and directly behind the driver door
2” dent near driver rear bumper
Some flaking paint along window edges
ABS light comes on sporadically
Airbag light is flashing a code
A/C system could use a recharge
Heater can be a little finicky
1995 E250 Coachmen w/ complete rebuild - 59k miles
Re: 1995 E250 Coachmen w/ complete rebuild - 59k miles
That's an interesting van. I love how many different companies were making B vans in the 90s.
Please add the VIN per the forum rules.
Thanks.
Thanks.
Ah yes I will update that. Thank you for the reminder!
Price Drop!
Did I mention that I made $18k last year renting out out 1996 Roadtrek?
AND I can deliver to anywhere on the West Coast, Midwest, and the Deep South!
