Onan Microlite 2800 KV Rev C Fan Hub Magnet
2800 MicroLite by Onan
James Baldwin
Post by James Baldwin »
Repairing my Onan Microlite 2800 KV Spec C generator which wouldn't keep running. Found the magneto magnet on the fan hub assy part # 205-0206 broken The fan hub assy is on longer available. Looking for the insert or the correct magnet to glue to the original insert.
The magnet is 46mm long (1.8"), 10.5mm (0.41") wide, 0.3mm thick (0.12"). There is not a part number in the manual for just the magnet or the insert for a Spec C only the complete fan hub.
The manual list the insert for Spec A-B as 134-4531. Any idea if it would fit a spec C fan hub assy?
So far this is the only part holding up the generators repair.
Jim
