Installed new bathtub ordered from PPL Motor Homes stock #88-4143 32x24 step r hand drain which Lyons Industries is the manufacturer #DT1832STR12 for $122.
1. Took out old tub which is 1/2" longer (32 1/2"). Tub in corner by front drain had developed cracks. Thickness of original very thin and soft vinyl.
2. There was no leakage caught it in time so all wood supporting tub in good shape.
3. Installed new sideboard in hole left open by Airstream.
4. New tub is reinforced fiberglass. Very strong to support weight.
5. Installed/glued 4x4 posts under tub platform to support new tub better
6. These were adjusted in height to allow for small difference in depth of tub
7. Reinstalled tub platform, check drain placement and height
8. Installed tub, checked level, installed drain, secured to walls, caulked.
9. Made border out of Trex to cover screws, protect for leakage and added 1/2" to back panel to make up for being short. Glued to walls and will caulk when dry
Pictures on my gallery gingfred b190
Took about 3 hours with my son and son-in-law
Very happy with new strong tub
New bathtub installation
Re: New bathtub installation
Old posts can be very helpful for newbies!
Thats why we're here.... !
This will help me.... mine has a hole.
- WBCCI: 8008
Thank you very much for this post. It gave me everything I needed to replace my tub. It turned out great and a much needed improvement.
- Tub.jpg (78.41 KiB) Viewed 12518 times
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Tucsonan
You did a great job!, ...I'm putting it on my list.FoCoKCCO wrote:Thank you very much for this post. It gave me everything I needed to replace my tub. It turned out great and a much needed improvement.
